A51 beeping noise
a.
I have a Samsung Galaxy A51 with Android 11. I bought it about a bit less than a year ago I think and I use old Samsung headphones (wired, not Bluetooth) from an older phone. They never caused any problems.
But since a few months, every time I plug in my headphones, after a few minutes, my phone starts beeping and it doesn't stop. I don't know if it's the case everytime but sometimes it starts beeping after I received a notification.
I already tried everything I can imagine. I turned off the notification reminder and NFC, I googled for about three hours, I closed every app while it was beeping and also turned off the notifications for every app while the phone was beeping.
The beeping stops if I restart my phone but I hope to find or get a solution to solve the problem permanently.
I hope you can help me. Thanks in advance.
I don't think that the problem are the headphones. I also need those on my computer and there this doesn't happen.
Have you ever used other headphones to localize the problem?
He wrote so. After that the problem has gone for a while.
You only look for software problems, what is the resson for this? So you don't everything to localize your problem.
or even he can go to assistance and then on live chat and explain the problem.*1f642.png*
Yes, I also tried restarting but that isn't a permanent solution.
I now tried other headphones and it happened with these too.
go to (text chat) you can explain your problem:)
On 05.12.2023 I updated to Android 14 using OTA. and everything went as it should. But after install I noticed fast battery drain and the phone display is hot to the touch even while i'm writing here, when i listen to the music using BT earphones the display is also hot even if it's off. I read...
Hi I have a Samsung a04e phoneAnd I updated to android 13 - one ui 5.1 All things perfect but when I try to download Good luck app I didn't find it on samsoung store And I think my phone doesn't support it So how I can know if my phone support good luck or what is the problem Gelöst...
How much am I waiting for the android 14 Update? I have an A33 5g and it was supposed to be coming out today for my phone, but I never got it, can someone help me 8580157
Since a few weeks, almost all the apps on my A52s 5G prompt a message after just a few minutes of normal usage that there is no Internet connection (or something of the like), or the apps stop working/refreshing. At first, I thought this was an issue with Meta apps (Insta, WhatsApp, etc.). But...
Hi everybody, Since few days, the wide angle camera of my Samsung A53 5G stopped working. When I select the 0.5x zoom from the standard camera app, I get an error message (Warning, camera error). I tried to clear the cache, restart the phone, restart in safe mode, without success. I tried also...
