A52S 5G overheating and fast battery draining
P.
On 05.12.2023 I updated to Android 14 using OTA. and everything went as it should.
But after install I noticed fast battery drain and the phone display is hot to the touch even while i'm writing here, when i listen to the music using BT earphones the display is also hot even if it's off.
I read that the google pixel had issues with Android 14 at the beginning. But I was looking online about samsung phones having this issue with Android 14 but could't find anything.
Now my question is, is this happening only to my A52s or is it known issue for now and getting fixed?
Since a few weeks, almost all the apps on my A52s 5G prompt a message after just a few minutes of normal usage that there is no Internet connection (or something of the like), or the apps stop working/refreshing. At first, I thought this was an issue with Meta apps (Insta, WhatsApp, etc.). But...
Hello, I inserted a 64 GB micro sd card into my Galaxy A 52 and I am able to view all the stored pictures and videos in my Gallery. I was also able to change the settings to save taken pictures directly to the SD card, so everything seems to work fine. However when I open 'samsung my files' it...
Hello, two weeks ago my Galaxy A52 4g went into a bootloop after installing the latest update. It then loaded into android recovery and I had to factory reset the phone in order for it to start normally. I've been using it and it has been working fine after the factory reset, but I wanted to...
I'm not sure when it happened, but viewing the all apps screen and switching to the work profile apps is now close to impossible. The Work Profile button is seemingly behind the back button now, which means every time I try to tap it, it prioritizes the back action over going to the work...
I am using Samsung A52s 5g. When I record slow motion videos, the video comes with fully blurred and with very low quality. 64mp camera works fine but this is very much disappointing. #A52s #SamsungA52s, #Slowmotion, #Camera, #Quality 4611025
