Analog Watch Face for Watch 5
b.
Since 5 days I'm a proud owner of the watch 5. It's a great machine, though I am still looking for a perfect analog watch face. I am surprised that obviously everybody ist ok with the fact that each of the hands at certain times obscure the complication placement. You want to look at todays date and daaaaa..., i can't read it because right now the minute hand obscures it. On my now broken Pebble watch I had an analog watch face were the date window moved to another quadrant as soon as a hand came near it. Wouldn't it be great if a Samsung watch could show this feature?
I am hoping that somebody could design this thing for Samsung.
If you want something done well, do it yourself. With watchmaker.
Napoleon Bonaparte (maybe maybe not)
du könntest auch mal hier nach einem alternativen Ziffernblatt schauen
I wore the watch 24x7 (except 1 hour daily charging) for about 2 months. Occasionally it was uncomfortable or sweaty but mostly it was very comfortable. One day I observed the skin under by watch was a little hard with minor swelling. I decided to not wear the watch for 2-3 days to let the wrist...
Hello, I was using my Galaxy Active watch for 2 years and it worked perfectly. Then it received an update, and last thing i saw in the watch was something like "Now you can use Samsung Pay, check your phone to continue with the update". I had not time to proceed and complete the update, and the...
Hi guys! I have a gear s3 frontier watch which I bought in the U.S and also a S10+ which i got from the U.S(i currently live in Germany). I recently got the s10+ and when I tried to link my watch to it, it says that there is a reactivation lock(Even after I tried a hard reset on it ) . So, i now...
Hello I have a problem with my left Bud if I connect it over bluetooth with ay device it makes an annoying beep pause beep tone. After the problem orccured I gave it a neat clean which fixed the problem for about a minute after that it started beeping. I suspect some kind of loose contact inside...
 I just found out that if you go to the testing menu at the galaxy watch 5, you can se a temperature. The temperature also changes if i put the watch into water, so the temperature sensor already works or? Gelöst! L: Gehe zu...
Q
