Charging
d.
My 25w charger was showing me super fast charging but it's only fast charge and it's slower
    Holy sh.. 25 kw charger. I think your Phone will melt. Minimum chargingspeed Warp 8
    Sorry I mean 25w :rofl::rofl::rofl:
    Die Ladezeit zwischen Superfast und Fast differiert lediglich um wenige Minuten, aber er müsste es schon korrekt anzeigen. Evtl mal die USB Einstellungen resetten .
    Null, das ist bei mir genetisch bedingt:rolleyes:*1f601.png**1f633.png*
    Das habe ich befürchtet.
    Wir haben früher zu Hause viel gelacht und Blödsinn gemacht weil meine Eltern durch den WW2 praktisch keine Kindheit hatten, das haben die dann mit uns nachgeholt. War spaßig
    Please reestablish the action bar information, that says if you are charging, fast charging, super fast charging or ultra fast charging... 7081626
    I have a charger that supports the super fast charging on my S20 FE 5G but when i try to charge my S9 plus it doesnt charge at all. Not even normal. Does anyone know what the reason could be? 4202750
    Hello, since two weeks I’m not able to charge my phone via an USB-C charger. If I charge it via normal USB it works - but slow. I thought the issue comes from the USB connector module, but after replacing it I still face the same issue. Basically, any charging device with USB-C exit does not...
    German (Google Translate, sorry): Ich kaufte mein Galaxy S8 am 27. September. Immer wenn ich mein Ladegerät anschließe (original Samsung "Adaptive Fast Charging") schaltet der Stutus des Gerätes zwischen Aufladen und Nichtladen alle paar Sekunden um. Ich muss das Ladegerät mehrfach trennen und...
    I got my long waited S22 Ultra yesterday after more that 5 weeks of waiting. Unfortunately I don't have yet the USB C dock charger so I used the old one to charge it. Today I connect it to my laptop with the USB C cable provided in the box, surprise!!! the cable works only on the "charging port"...
