com.android.settings is being closed repeatedly
r.
My problem is pretty much in the title. I constantly get the notification that com.android.settings is being closed repeatedly. I don't know what to do, all help is very much appreciated!
Like other apps, the Settings app also stores cache and data files on your phone. Sometimes, these files are why you have the unfortunately com.android.settings has stopped issue on your device. You can fix it by clearing these files.
Go to Settings > Apps & notifications > See all apps, tap the three-dots at the top-right corner, and choose Show system.
Tap on the Settings app, choose Storage, and tap both Clear Storage and Clear Cache one by one.
The issue should now be fixed.
Source: [SOLVED]Com.Android.Settings has Stopped on Android
If this not works follow the next:
Switch the Phone Off.
Connect it via USB to a running Computer.
If the charging Logo appears press the Vol up and the Power Button the same time for about 5 sec. You will enter a Revovery Menue.
There you can choose several Points.
Take the point Wipe Data. You can toggle the points by pressing Volume up or Volume down. You confirm your choice by pressing the Power Button shortly. For your safety: NO Data will lost by doing this !
Be careful: Do not choose the Point Factory Reset, in case you choose this ALL Data will be lost!
Moin L: @relativokay
Was ist mit Updates?
Bist Du bei Galaxy und Play Store gut davor?
Fehlt Dir ein Update?
Bin mir nicht ganz sicher, glaube das Android Web System ist mit dabei .
Da gab es hier vor drei Tagen ein Update.
Einstellungen.
Apps.
" mittig " ihre Apps, rechts davon so drei waagerechte Striche tippen.
Schalte oben Systemanwendungen anzeigen an und unten auf OK tippen.
Suche oben Android Web System.
Im Speicher lösche zuerst einmal die Cache.
Alles schließen, Handy Neustart.
Was passiert jetzt?
I'm not sure when it happened, but viewing the all apps screen and switching to the work profile apps is now close to impossible. The Work Profile button is seemingly behind the back button now, which means every time I try to tap it, it prioritizes the back action over going to the work...
Since a few weeks, almost all the apps on my A52s 5G prompt a message after just a few minutes of normal usage that there is no Internet connection (or something of the like), or the apps stop working/refreshing. At first, I thought this was an issue with Meta apps (Insta, WhatsApp, etc.). But...
I have a Samsung Galaxy A51 with Android 11. I bought it about a bit less than a year ago I think and I use old Samsung headphones (wired, not Bluetooth) from an older phone. They never caused any problems. But since a few months, every time I plug in my headphones, after a few minutes, my...
Hi everybody, Since few days, the wide angle camera of my Samsung A53 5G stopped working. When I select the 0.5x zoom from the standard camera app, I get an error message (Warning, camera error). I tried to clear the cache, restart the phone, restart in safe mode, without success. I tried also...
Hi I have a Samsung a04e phoneAnd I updated to android 13 - one ui 5.1 All things perfect but when I try to download Good luck app I didn't find it on samsoung store And I think my phone doesn't support it So how I can know if my phone support good luck or what is the problem Gelöst...
