Connecting Headphonejack triggers Google Assistant
D.
Hello people.
I got some cheap headphone jack and everytime I connect it to my device it tells me to turn Google Assistant on for assistance. I don't want to use Google Assistant and have turned it off but it keeps asking me every time I connect the dongle. Is there a way I can stop that? Or is it a kind of a bug because the headphone jack has some kind of digital analog converter chip built in?
Help would be appreciated, thanks in advance
Try this;
Settings》Google》Search, Assistant and Voice 》Voice》Allow wired headset requests with device locked》Turn it Off
Btw: the headphone jack dongle does have a dac built in
Thx for your reply.
I did that already. The problem still there
i mean.. you could clear data or even uninstall the assistant
Hi, When I switch from selfie to main camera (or back) during a video, I get a harsh clicking sound. Any Idea what is causing that? Is it my finger tapping the display to switch or is it a switch on microphones?  Tipps appreciated.  8760227
Hello, I apologise that I'm writing in english but it is easier for me to explain the problem. I have a frustrating issue with my phone. I bought Samsung S23 as a brand new around 3 months ago. It was working fine till last week - I started to have problems with the signal connetion - the...
I am using S23ultra and it's a bad feeling to see that it is not smooth as it should be, for instance every time I open Galaxy store for apps or update it lags the UI isn't fluid unlike google playstore which feels better to open and use.  Do you guys feel the same ?????? I totally love my...
After having upgraded the S23 Ultra to android 14 and one ui 6.0 I'm having big connectivity and battery problems. The reception is bad, absent or at most a notch and the people I call can't hear me! Even the internet connection it's of course not there.  I tried to switch the sim to a Samsung...
I have a s23 from India and I am unable to use my samsung wallet in Germany. It doesn't allow me to add international cards. Could anyone tell me a workaround this on how i can start using Google wallet or Samsung pay in Europe. 8564921
