distorted notification sound on galaxy 20 ultra when the galaxy buds 2 are on
Recenly I've noticed that when i wear my galaxy buds 2, and a notification sound or when someone calls me the notification sound goes out from my note 20 ultra's speaker distorted it feels like the speaker is broken and the issue goes when i dont wear the buds!
I think the problem is happening because there is kind of Synchronisation in the notification sound between the buds and the actual phone speaker, because you can hear the notification sound in both the phobe and the buds.
Plus when i disabled Sync ringtone option the issue got fixed when someone calls me but still on other notification sounds especially on Facebook notifications.
Hast du die buds schon mal resettet?
Did you already try a reset of the Buds?
I am experiencing an issue with notification Sound on my galaxy s23. I needed to turn off sounds due to a Meeting I had. When I turned sounds back on I no longer receive notification sounds or keyboard typing sounds. Ring Tones for calls seem to work properly. It is Not a setting issue with my...
Samsung should consider adding an option to the Galaxy Buds Pro to turn off the sound that plays when you plug them in the ear. Because sometimes it just goes off randomly even though the buds sit tight. I doubt that I'm the only one having this problem. I'm on the latest update. 2810436
Hi guys today I found a bug of a sort with WhatsApp and my Samsung galaxy note 20 Ultra. I want WhatsApps messages to be silent but still be displayed on the notification bar. This seems to be impossible because when I get a notification from WhatsApp, the app doesn't play a sound but the phone...
The recent Update on my S22 Ultra somehow disabled all the stock Ringtones and notifications. Alarm sound not working and none of the Text or call sounds work. Trying to change the ringtone to another one gives an error that it is not supported. 5392883
There is always some noise in one of my Buds Pro earphone when I turn on the Active Noise Canceling mode. I have used Buds Pro for 1.5 years, so it can not be repaired freely. The repair center told me I should pay 80 Euro to repair the Buds Pro. I have talked with the online Chat service...
