Distortion in Buds after update?
C.
After getting the most recent software update for the Galaxy Buds 2, I noticed a slight crackling noise in both my earbuds when listening to audio. If I go back in the song/video, it happens to be the exact same spot where the audio cuts and the crackling noise sets in for a quick moment, after which the audio continues regularly. This cycle repeats itself multiple times throughout a video/song. If anyone has experienced similar stuff please reach out.
Some actually have this issue and even before the update the Buds 2 had connection issues. I thought the update would fix the problem, but that wasn't the case‍*2640.png*.
Zur Not Kopplung löschen und alles neu verbinden.
Das ist ein bekanntes Problem zu dem es keine Lösung gibt ‍*2640.png*
Dann hätte ich besser mal die SuFu genutzt, dann gibt es sicher ettliche Postings dazu......
:think: :rofl: *1f623.png* ;) *1f605.png*
Das Problem kommt einfach plötzlich und unerwartet. Das nervt aber richtig :rofl: :rofl:
Hello I have a problem with my left Bud if I connect it over bluetooth with ay device it makes an annoying beep pause beep tone. After the problem orccured I gave it a neat clean which fixed the problem for about a minute after that it started beeping. I suspect some kind of loose contact inside...
There is always some noise in one of my Buds Pro earphone when I turn on the Active Noise Canceling mode. I have used Buds Pro for 1.5 years, so it can not be repaired freely. The repair center told me I should pay 80 Euro to repair the Buds Pro. I have talked with the online Chat service...
Pumping the beats! I left one of the buds in my pants pocket and they got tossed in the dirty basket. Well, apparently the bud went through a entire wash cycle, with soap, and then it was found in the dryer at the end of the cycle when removing the clothes. Fearing the worse, I popped it in the...
Hello, I was using my Galaxy Active watch for 2 years and it worked perfectly. Then it received an update, and last thing i saw in the watch was something like "Now you can use Samsung Pay, check your phone to continue with the update". I had not time to proceed and complete the update, and the...
It's never being accurate thatsself explanatory but somewhat would help I checked my calories burned for a 47 year old been working out 35 years and go to the gym Every day and do cardio on daily basis between 45 min to 60 min . As an average I would burn about 2500 kcl a day doing nothing at...
