Frame Firmware 1392 hdmi Problem
After installation of Firmware 1392 on my Frame 49 (Modelcode: QE49LS03RAUXZG) I have huge HDMI sync problems. Everytime when I move a running Windows 11 Window on this Frame as an external monitor the HDMI sync crashes. Most of the time, the resync happens after ~5 sec.
It is not possible to use this Frame anymore as an external monitor.
Did you already try a reset of the TV and a reset of the Smart Hub?
Hi, I am an artist producing artworks involving a computer and a vertical The Frame display. To make my art installation nicer for the end user, I want that the only user interaction is one touch on the computer power button. The computer turns on, sends a WakeOnLan signal to the TV which turns...
Hello, I bought S22 ultra few days back. It is brand new. After setting up the device it got many updates and the latest update is One UI 6 based on android 14. I have seen significanr battery draining. For example if I charge it full then unplug it, in the morning I see 19% charge is already...
So I'm currently having this problem.I connect my S20FE via an usb-c to hdmi adapter to a tv and between the span of 5 seconds to 1 minute the screen goes completely black, the audio cuts out for a few seconds and then turns back on. This also sometimes happens rapidly every ca 3-10 seconds the...
Hello, I apologise that I'm writing in english but it is easier for me to explain the problem. I have a frustrating issue with my phone. I bought Samsung S23 as a brand new around 3 months ago. It was working fine till last week - I started to have problems with the signal connetion - the...
Hello everyone, I just received today my Galaxy Book Flex2 i7 and I have two concerns that I would like to know whether they are normal or I have had bad luck and got a defect device: 1. The touchpad click is triggering a "rattling sound" as if some keys on the keyboard were loose. The left...
