GALAXY BOOK 3 PRO 360 LAGS
N.
Hello all, I recently purchased Samsung galaxy book 3 pro 360 and whenever it goes into standby/sleep mode for sometime and I switch the screen on, it becomes so laggy and almost unusable. I have to switch it off before this stops and the switching off can take minutes because it becomes so laggy that everything seems unresponsive. Please help me out.
Hallo Ntobase,
dies ist die deutsche Samsung User Community. Samsung liest hier nicht mit.
Wenn du in deutsch schreibst, dann klappt die Kommunikation besser als über eine gemeinsame Fremdsprache *m:1f609.png*
Hi L: @Ntoboase and welcome.
Did you have this problem from the start, or did it only appear over time? Have you subsequently installed any programs that are now running in the background and are slowing down your system because they are taking up too much memory?
Have a look in the Windows Task Manager which task takes up how much power from the system.
Which energy saving options do you have activated?
Are all your Windows and programs/apps and drivers up to date?
Check everything and let me know if you were able to eliminate the error. *m:270c.png*
I have one additional tip. Press and hold the Shift key while shutting down Windows. This actually shuts down Windows completely and also deletes all cached files. If you exit Windows like this, you have to press the power button to restart.
Hello all, Will the Samsung galaxy book 3 pro 360 laptop have the beige color option in Germany?. When is this likely as today marks the end of the pre-order offers? I have waited for sometime but it seems not to appear on the Samsung website. Any help? 6938021
The Screen on my Samsung Galaxy Book Pro 360 crackeded while picking it up, the device was closed, I picked ot up and started hearing a creeking sound so i opend it an there where tiny cracks all over the screen... The rest of the Notebook still works fine. Pictures below: Gelöst...
I had recently purchased (one month) my Samsung Galaxy notebook pro 2 to support in my studies in university. But the device seems to be not relaible as it is keep crashing everytime I open any application and samsung pen got within the device from samsung is showing to many glitches when...
Hat schon jemand das Galaxy Book 3 Pro 360? Wie sind eure Erfahrungen? 6930754
Liebe Community, ich habe eine Frage zu den beiden Modellen Samsung Galaxy Book 3 Pro 360 und Ultra, beide haben 16 Zoll Displays, gibt es Unterschied oder kann ich auch eine Ultra Schutzfolie kaufen und die passt dann auch auf das Display des 3 Pro 360 ? 6890106
