Galaxy S9 DUOS does not update since January
A.
Hi,
i'm from Italy
I have a S9 DUOS
I contacted the Italian community but was told that the firmware I currently have installed should be the one released by Samsung Germany in January (but I bought the phone in Italy).
Until January I have always received regular updates without problems.
From January if I try to do "software updates" the answer is always the same: "the software is updated"
Yet I am still with the G960FXXU2CSA2/G960FOXM2CSA2/G960FXXU2CRLI
Below the Software Information screen:
Can you help me to make all the latest updates?
Thank you so much
Matteo from Milan
Hi Matteo,
please try to install the update with Smart Switch on a PC.
Hi David,
Thanks for the reply.
I have already tried to update from phone and with Smart Switch on PC... without results.
Until January it made automatic updates without problems.
Hi, L: @Artikal do you have Samsumg Service centers somewhere near to you ?
If yes then get there and let the Service install you the newest Italian firmware so it gets back to normal.
If I open instagram either from Google Play or from the menu it opens but I have a screen with no options. I tried uninstalling but on the S23Ultra you can't completely uninstall the app. I did clear the data and cache already but to no result. 7988157
Hi all, I bought Galaxy S9 last year, now I moved back to my home country. When I insert local SIM card on my phone, it does not make a phone call. other functions are working well, search as Data, SMS and others, Only not Phone call. I tried to find other options in the setting but never...
I have a samsung A50 purchased in India. I purchased an Active 2 watch in Germany. I changed my account's region to Germany but I cannot use the Health Monitor app. It says the service is currently not available at my locaton 3433570
Hello everyone, I just received today my Galaxy Book Flex2 i7 and I have two concerns that I would like to know whether they are normal or I have had bad luck and got a defect device: 1. The touchpad click is triggering a "rattling sound" as if some keys on the keyboard were loose. The left...
There is always some noise in one of my Buds Pro earphone when I turn on the Active Noise Canceling mode. I have used Buds Pro for 1.5 years, so it can not be repaired freely. The repair center told me I should pay 80 Euro to repair the Buds Pro. I have talked with the online Chat service...
