Galaxy store
I am using S23ultra and it's a bad feeling to see that it is not smooth as it should be, for instance every time I open Galaxy store for apps or update it lags the UI isn't fluid unlike google playstore which feels better to open and use.
Do you guys feel the same ??????
I totally love my device and I request Samsung to work on UI smoothness and fluidity It should be appealing to the eyes.
Apart from that thank you for such a great device and putting snapdragon chip in it*m:270c_1f3fb.png*
you can try downloading Good Guardians and then inside the app, install "Galaxy App Booster" on Galaxy Store. This may help improve performance by up to 5-15%.
Alternatively, you can also try wiping the cache partition in recovery.
Hello 1Lastrude,
Hello, may I ask, did you buy the s23ultra from Samsung or from a privider with a cell phone contract... or even online or from a dealer? - is your S23 only sluggish at the Galaxy Store or somewhere else?
Andi
I order from online galaxy store
And sluggish noticeably for galaxy store app
The best you can do is, as I said above, wipe the cache and repair the apps. Alternatively, you can use the Galaxy-App - Booster to improve overall performance.
I've got all the time same issue like you, in Galaxy store, in Google Chrome, is not smoothly switching and gliding as in other apps. Even when I'm on energy save mode it's really horrible and very enjoying.... But this is not the problem from your device, it is the web using behind the app, that is telling from a Samsung support master in the past I'm asking for it.
Hope they fix it with the next Android upgrade *m:1f64f.png*
Try: Chrome > three dots in the top right corner > Website Settings > Saved Data > delete everything there
then restart the phone
Im from germany. Hope the translation is right.
What's the big deal? The Galaxy Shop is a service in the Internet. It doesn't render your phone unusable.
And while that store is sluggish and quirky, we don't spend much time there. So what.
Let's move on.
Wow das ist ja mal was neues!
Keiner hier der jammert! das kein Deutsch geschrieben wird.
Dass heißt alle können Englisch auch *m:1f603.png**m:270c_1f3fb.png*
Hello people. I got some cheap headphone jack and everytime I connect it to my device it tells me to turn Google Assistant on for assistance. I don't want to use Google Assistant and have turned it off but it keeps asking me every time I connect the dongle. Is there a way I can stop that? Or is...
If I open instagram either from Google Play or from the menu it opens but I have a screen with no options. I tried uninstalling but on the S23Ultra you can't completely uninstall the app. I did clear the data and cache already but to no result. 7988157
Hello, I apologise that I'm writing in english but it is easier for me to explain the problem. I have a frustrating issue with my phone. I bought Samsung S23 as a brand new around 3 months ago. It was working fine till last week - I started to have problems with the signal connetion - the...
The back swipe gesture isnt working sometimes on Facebook, and as an always Samsung fan, please improve the responsiveness of bottom swipe gesture and also the quick panel its not smooth sometimes i need to touch more than once the bottom swipe gesture to move the quick panel back. This is so...
Hello I have a problem with my left Bud if I connect it over bluetooth with ay device it makes an annoying beep pause beep tone. After the problem orccured I gave it a neat clean which fixed the problem for about a minute after that it started beeping. I suspect some kind of loose contact inside...
