Imei2 problem
B.
Hi friends. Sorry for writing in English because my German is not that much good. I have a emergency problem with a Galaxy S10 cell phone. I hope that this is the right place for askig the question. I'm buying a second hand phone (which is actually is new and the owner got it as an contract extension). The problem is every thing is alright about the cell phone but IMEI2 number of the cell phone is not matching what it has on the box.
The wired thing is IMEI1 is matching perfectly between the cell phone and the box.
There are 2 IMEI since the cell phone is dual.
Do you have any idea what can be wrong with the cell phone? Should I buy it or not? Any suggestions?
Thank you very much
You could look on the back-glass of the phone where the Imei number is standing if it matches with the System or the box.
I would not recommend to buy it if it doesn't match with any original IMEI number embedded in the software.
Hello L: @Baharmast,
did Eisik's answer help you?
Best regards
Hi, quick question; before I updated to android 10, I had a Smarthings device panel directly in my Notificationcenter. It showed a seperate icon vor every connected device along with its battery status and a little extra button for smartview. I loved that feature! I could see how much battery...
Hello, I have recently bought a new Samsung Galaxy M32 phone and I'm having a sound problem. When I play music using wired headphones, there is a constant clicking noise on the background and it keeps playing until the music is stopped! I don't know how to get rid of it, please can someone help...
Hi there, is the SIM / SD Card holder of your Samsung Galaxy S7 also not levelly? Mine sticks out a bit and the gap size betwwen it and the housing of the phone is uneven too. What is your opinion on this and do you think I should return my phone? Only got it 2 weeks ago. Cheers Erik...
It's possible that the screen is broken after a 20cm fall?? In a device that cost only 800€!!Broken after a month! Ah and dont forget the 60€ for the led cover, beautiful nothing to say, but if it open when fall what must protect?? Now if you can tell me what is the best way to get it repaired...
I've got a Samsung S8+ and I don't want to ring out all people arround me only because of that I am very often in a very loud place. So I want to get it working in the way that it starts with a low ring and increases this over an adjustable time to a high ring. If I would programm it I would do...
