Is standard video better than pro video on Samsung Galaxy s20?
a.
Hi everyone,
-Is standard video better than pro video on Samsung galaxy s20? I tried to change parameters like ISO, and speed on pro video. But pro video's quality is still worse than standard video. Does anyone know why there is that difference? Because I could not see the parameter in standard video, then I have to use pro video. But It did not give me the same quality.
- Or does anyone know how I can see these parameters in the standard video? Thank you so much
Best regards,
#provdideo #camera#S20 #Galaxy
  • One UI 6.1 integriert Galaxy AI in die Samsung-Apps Notizen, Tastatur und Sprachrekorder
    One UI 6.1 integriert Galaxy AI in die Samsung-Apps Notizen, Tastatur und SprachrekorderGalaxy AI soll die Art und Weise, wie Sie mit Ihrem Samsung-Gerät interagieren, revolutionieren. Die kürzlich vorgestellte Galaxy S24-Serie ist Samsungs erste KI-gestützte Produktreihe. Es ist interessant zu wissen, dass Googles KI-Modell Gemini Pro KI-Funktionen in die Samsung Galaxy S24-Smartphones einbringt. Samsung ist der erste Google Cloud-Partner, der Gemini Pro auf Vertex einsetzt [...]
Is there a reason you want to see this information? For me, when I use Pro Video and set all params to Standard/Automatic, I get a very similar result to the normal camera. If you do not know, what the params are, or what they do, then you will just be better off using the normal video function. I dont think you can show the stats while filming the video in the normal mode.
The reason why the standard video might seem higher quality is the automatic editing/adjustments the App does. The Pro Mode is supposed to give you more of a "raw" output so that you can edit it afterwards if you wish to do so.
Hi GalaxyDodo,
Thank you so much for your reply. I would like to see this information because I have to collect some videos for AI. I have to set up one small room that isolates light from outside. This room must be totally dark. And I just have two light sources that point to my face. I have to hold my hand before my eyes. So when I take a video, I have to see my hand clearly on my irises. With a normal camera, it works perfectly. But I cannot see parameters with a normal video. So I use pro video with parameters. But I do not get the same result like a normal video. The hand in my irises is somehow not clear. I adjusted parameters or tried many combinations of these parameters. It still does not work *1f61e.png* Do you have any idea?
Thank you so much
Best regards
My best guess is that the Pro Video uses the wrong lens for the situation.. But afaik you cannot change the lens on pro video on the s20..
Or do you know how to disable auto-adjusting on a normal camera? It would be helpful for me as well
You can hold down on the point you want to focus until the AF gets locked (yellow circle). Then you can at least adjust the brightness to a fixed value and the focus will also be locked.
Thank you for your suggestion. It is really helpful for me. Do you know which unit the focus parameter has with the pro video? Do we have an aperture parameter on pro video?
Wdym which unit? There is a "focus" parameter in the pro mode.
I mean which unit does a focus parameter have (e.g 0.6 meters or millimeters). Because I do not see any unit information about focus parameter
Guten Tag, bei der Videoaufnahme habe ich folgendes Problem. Das Bild auf dem Display sieht gut aus, sobald ich auf Videoaufnahme tippe wird das Aufnahmebild dunkler als das ursprüngliche Bild auf dem Display. Ich versuche ein Kochvideo aufzunehmen und habe trotz ausreichender Beleuchtung ein...
Hello, I am using S22 ultra which is great. However, I having trouble during video calls especially during whatsapp video calls as phone heats up a lot. It overheats so much that I think its going to burst. My friend has the same phone but his phone overheats only during 4k videos. Does this...
Hi all, I just bought a Samsung A40. I got very used to the always on feature of my A3 but can't find it on the A40. Is it somehow hidden or just not supported yet? Thx, Maxim 1121164
Hello All, Is there any else facing trouble while recording videos at 120fps FHD (in pro video mode)? My s21ultra only seems to be recording at max 60fps FHD. I tried contacting Samsung support but it didn't help. I wonder if anyone else faced a similar problem and solved it. With best...
the picture on my tv randomly darkens when playing video games on the pc, if I then go to the settings in dimming from low to standard the brightness is back to normal - I know that was an old problem but with me it is only since the new update before I never had it. and it also happens in...
