o.
seit Monaten habe ich das Problem, dass Samsung Magician nach dem Rechnerstart die SMART Daten nicht anzeigt. Das geht erst später.
08-08-2021 10:24:00 ERROR SILCommands ATACommandBase::_CheckFisAndThrow 145 Device aborted. STATUS[0x51], ERROR[0x4]
08-08-2021 10:24:00 INFO BDIM DiskInfoManager::_FillDiskInfoComm 624 [DISK 1] Samsung SSD 860 EVO 500GB, S4XBNF1M914939X, RVT04B6Q, PHYSICALDRIVE 3
08-08-2021 10:24:00 INFO BDIM DiskInfoManager::_FillOneDiskInfo 502 [DISK 1] \\?\scsi#disk&ven_samsung&prod_ssd_860_evo_500g#4&31b67fd&0&050000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
08-08-2021 10:24:00 ERROR SILCommands ATACommandBase::_CheckAbortBitAndZeroBufferAndRethrow124 Buffer all zero
08-08-2021 10:24:00 ERROR SILA00 SILDevSmartInfoAta::Execute 64 SILCommands Exception, code: 10, system err: 0
08-08-2021 10:24:00 ERROR BDIM DiskInfoManager::UpdateSMARTInfo 323 Get SMART Failed with error code[6]
08-08-2021 10:24:00 ERROR BDIM DiskInfoManager::_ScanOneDevice 224 SMART Failed with error code[2]
08-08-2021 10:24:00 INFO BSIM FillDiskInfoImpWin32::_GetParamsForDriver 848 SATA Mode for checking the AHCI Mode. PCI BUS Number is valid [0]
08-08-2021 10:24:00 ERROR BDD FilesClassifyScanMgr::GetNewClassify_Details 143 No NVMe Disk Info detected for drive:F:\
08-08-2021 10:24:00 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[1]
08-08-2021 10:24:00 ERROR DDF DDF::_GetOneDiskInfo 257 smart disk object not found
08-08-2021 10:24:00 INFO DriveDetails DriveDetails::RequestDone 501 Update device information is completed.
08-08-2021 10:24:04 INFO Home HOME::ShowView 1644 Enter Drive Information screen False False
08-08-2021 10:24:04 INFO Home HOME::UpdateDevInfo 171 Update device information is started.
08-08-2021 10:24:05 INFO BDIM DiskInfoManager::UpdateDiskInfoHome 158 [TOTAL DISK COUNT : 4]
08-08-2021 10:24:05 ERROR SILCommands ATACommandBase::_CheckFisAndThrow 145 Device aborted. STATUS[0x51], ERROR[0x4]
08-08-2021 10:24:05 ERROR SILCommands ATACommandBase::_CheckAbortBitAndZeroBufferAndRethrow124 Buffer all zero
08-08-2021 10:24:05 ERROR SILA00 SILDevSmartInfoAta::Execute 64 SILCommands Exception, code: 10, system err: 0
08-08-2021 10:24:05 ERROR BDIM DiskInfoManager::UpdateSMARTInfo 323 Get SMART Failed with error code[6]
08-08-2021 10:24:05 ERROR BDIM DiskInfoManager::_ScanOneDevice 224 SMART Failed with error code[2]
08-08-2021 10:24:05 INFO BDIM DiskInfoManager::_FillDiskInfoComm 624 [DISK 0] ST3000DM001-1ER166, Z50071PD, CC43, PHYSICALDRIVE 1
08-08-2021 10:24:05 INFO BDIM DiskInfoManager::_FillOneDiskInfo 502 [DISK 0] \\?\scsi#disk&ven_&prod_st3000dm001-1er1#4&31b67fd&0&010000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
08-08-2021 10:24:05 INFO BDIM DiskInfoManager::_FillDiskInfoComm 624 [DISK 2] Samsung SSD 840 EVO 250GB, S1DBNSAF266874Y, EXT0DB6Q, PHYSICALDRIVE 0
08-08-2021 10:24:05 INFO BDIM DiskInfoManager::_FillOneDiskInfo 502 [DISK 2] \\?\scsi#disk&ven_samsung&prod_ssd_840_evo_250g#4&31b67fd&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
08-08-2021 10:24:05 INFO BDIM DiskInfoManager::_FillDiskInfoComm 624 [DISK 1] Samsung SSD 860 EVO 500GB, S4XBNF1M914939X, RVT04B6Q, PHYSICALDRIVE 3
08-08-2021 10:24:05 INFO BDIM DiskInfoManager::_FillOneDiskInfo 502 [DISK 1] \\?\scsi#disk&ven_samsung&prod_ssd_860_evo_500g#4&31b67fd&0&050000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
08-08-2021 10:24:05 INFO BDIM DiskInfoManager::_FillDiskInfoComm 624 [DISK 3] Samsung SSD 860 EVO 500GB, S3Z2NB0K262772X, RVT04B6Q, PHYSICALDRIVE 2
08-08-2021 10:24:05 INFO BDIM DiskInfoManager::_FillOneDiskInfo 502 [DISK 3] \\?\scsi#disk&ven_samsung&prod_ssd_860_evo_500g#4&31b67fd&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
08-08-2021 10:24:05 INFO BSIM FillDiskInfoImpWin32::_GetParamsForDriver 848 SATA Mode for checking the AHCI Mode. PCI BUS Number is valid [0]
08-08-2021 10:24:05 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[2]
08-08-2021 10:24:05 ERROR HOMEF HOMEF::_GetBasicDiskInfo 339 smart disk object not found
08-08-2021 10:24:05 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[1]
08-08-2021 10:24:05 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[3]
08-08-2021 10:24:05 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[0]
08-08-2021 10:24:05 INFO Home HOME::RequestDone 274 Update device information is completed.
08-08-2021 10:24:07 INFO SM6 MainWindow::btn_REFRESH_Click 1234 Refresh started.
08-08-2021 10:24:07 INFO UIMP UIMgr::Refresh 1312 Rescan initiated
08-08-2021 10:24:07 INFO BVM VersionManager::SetMagicianVersionLocal 897 Begin collect file version
08-08-2021 10:24:07 INFO BVM VersionManager::SetMagicianVersionLocal 900 End collect file version
08-08-2021 10:24:07 INFO BVM VersionManager::SendT1 410 Begin send 1st data to server
08-08-2021 10:24:07 INFO FMM FmmImp::ScanDevices 324 Device scan started
08-08-2021 10:24:07 ERROR SILNL NVMeDevScanner::_ScanDevices 124 No NVMe device found
08-08-2021 10:24:07 ERROR SILNL NVMeDevScanner::_ScanImp 99 scan error eSILC_Err[3]
08-08-2021 10:24:07 INFO BDIM DiskInfoManager::UpdateDiskInfo 131 [TOTAL DISK COUNT : 4]
08-08-2021 10:24:07 INFO DiskInfoManager DiskInfoManager::_ScanOneDiskPartitionInfo 1208 ScanOneDiskPartitionInfo : Partition No[1], Style[0], Type[Primary Partition], Size[367001600]
08-08-2021 10:24:07 INFO DiskInfoManager DiskInfoManager::_ScanOneDiskPartitionInfo 1208 ScanOneDiskPartitionInfo : Partition No[2], Style[0], Type[Primary Partition], Size[249158828544]
08-08-2021 10:24:07 INFO DiskInfoManager DiskInfoManager::_ScanOneDiskPartitionInfo 1208 ScanOneDiskPartitionInfo : Partition No[3], Style[0], Type[Primary Partition], Size[530579456]
08-08-2021 10:24:07 INFO DiskInfoManager DiskInfoManager::_ScanOneDiskPartitionInfo 1208 ScanOneDiskPartitionInfo : Partition No[1], Style[1], Type[MS Reserved Partition], Size[134217728]
08-08-2021 10:24:07 INFO DiskInfoManager DiskInfoManager::_ScanOneDiskPartitionInfo 1208 ScanOneDiskPartitionInfo : Partition No[2], Style[1], Type[Primary Partition], Size[3000457232384]
08-08-2021 10:24:07 INFO DiskInfoManager DiskInfoManager::_ScanOneDiskPartitionInfo 1208 ScanOneDiskPartitionInfo : Partition No[1], Style[0], Type[Primary Partition], Size[500104691712]
08-08-2021 10:24:07 ERROR SILCommands ATACommandBase::_CheckFisAndThrow 145 Device aborted. STATUS[0x51], ERROR[0x4]
08-08-2021 10:24:07 INFO BDIM DiskInfoManager::_FillDiskInfoComm 624 [DISK 1] Samsung SSD 860 EVO 500GB, S4XBNF1M914939X, RVT04B6Q, PHYSICALDRIVE 3
08-08-2021 10:24:07 ERROR SILCommands ATACommandBase::_CheckAbortBitAndZeroBufferAndRethrow124 Buffer all zero
08-08-2021 10:24:07 INFO BDIM DiskInfoManager::_FillOneDiskInfo 502 [DISK 1] \\?\scsi#disk&ven_samsung&prod_ssd_860_evo_500g#4&31b67fd&0&050000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
08-08-2021 10:24:07 INFO BDIM DiskInfoManager::_FillDiskInfoComm 624 [DISK 2] Samsung SSD 840 EVO 250GB, S1DBNSAF266874Y, EXT0DB6Q, PHYSICALDRIVE 0
08-08-2021 10:24:07 ERROR SILA00 SILDevSmartInfoAta::Execute 64 SILCommands Exception, code: 10, system err: 0
08-08-2021 10:24:07 INFO BDIM DiskInfoManager::_FillOneDiskInfo 502 [DISK 2] \\?\scsi#disk&ven_samsung&prod_ssd_840_evo_250g#4&31b67fd&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
08-08-2021 10:24:07 ERROR BDIM DiskInfoManager::UpdateSMARTInfo 323 Get SMART Failed with error code[6]
08-08-2021 10:24:07 ERROR BDIM DiskInfoManager::_ScanOneDevice 224 SMART Failed with error code[2]
08-08-2021 10:24:07 INFO BDIM DiskInfoManager::_FillDiskInfoComm 624 [DISK 3] Samsung SSD 860 EVO 500GB, S3Z2NB0K262772X, RVT04B6Q, PHYSICALDRIVE 2
08-08-2021 10:24:07 INFO BDIM DiskInfoManager::_FillOneDiskInfo 502 [DISK 3] \\?\scsi#disk&ven_samsung&prod_ssd_860_evo_500g#4&31b67fd&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
08-08-2021 10:24:07 INFO BDIM DiskInfoManager::_FillDiskInfoComm 624 [DISK 0] ST3000DM001-1ER166, Z50071PD, CC43, PHYSICALDRIVE 1
08-08-2021 10:24:07 INFO BDIM DiskInfoManager::_FillOneDiskInfo 502 [DISK 0] \\?\scsi#disk&ven_&prod_st3000dm001-1er1#4&31b67fd&0&010000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
08-08-2021 10:24:08 INFO BSIM FillDiskInfoImpWin32::_GetParamsForDriver 848 SATA Mode for checking the AHCI Mode. PCI BUS Number is valid [0]
08-08-2021 10:24:08 INFO FMM FmmImp::_ScanDevicesImp 584 Disk info retrieved
08-08-2021 10:24:08 INFO FMM FmmImp::ScanDevices 345 Device scan completed
08-08-2021 10:24:08 INFO BVM VersionManager::SendT1 414 End send 1st data to server
08-08-2021 10:24:08 ERROR BSIM FillInfoForUPPLCImpWin32::_GetDrvInfoForUPPLC887 Enumeration returned 0 hr[1]
08-08-2021 10:24:08 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[0]
08-08-2021 10:24:08 ERROR UIMP UIMgr::_GetFeatureListViaT2 601 Failed to get smart object for disk[0]
08-08-2021 10:24:08 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[1]
08-08-2021 10:24:08 ERROR UIMP UIMgr::_GetFeatureListViaT2 601 Failed to get smart object for disk[1]
08-08-2021 10:24:08 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[2]
08-08-2021 10:24:08 ERROR UIMP UIMgr::_GetFeatureListViaT2 601 Failed to get smart object for disk[2]
08-08-2021 10:24:08 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[3]
08-08-2021 10:24:08 ERROR UIMP UIMgr::_GetFeatureListViaT2 601 Failed to get smart object for disk[3]
08-08-2021 10:24:08 INFO BVM VersionManager::SendT2AndParseData 453 Begin send 2nd data to server
08-08-2021 10:24:09 INFO BVM VersionManager::SendT2AndParseData 469 End send 2nd data to server
08-08-2021 10:24:09 INFO BVM VersionManager::SendT2AndParseData 476 Begin Parse 2nd data
08-08-2021 10:24:09 INFO BVM VersionManager::SendT2AndParseData 481 Begin set function data_1
08-08-2021 10:24:09 INFO BVM VersionManager::SendT2AndParseData 483 End set function data_1
08-08-2021 10:24:09 INFO BVM VersionManager::SendT2AndParseData 498 End parse 2nd data
08-08-2021 10:24:09 INFO SM6 MainWindow::FromUIM_BlockingOperationCompleted642 Refresh completed.
08-08-2021 10:24:09 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[2]
08-08-2021 10:24:09 ERROR HOMEF HOMEF::_GetBasicDiskInfo 339 smart disk object not found
08-08-2021 10:24:09 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[1]
08-08-2021 10:24:09 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[3]
08-08-2021 10:24:09 ERROR BDIM DiskInfoManager::GetNewSmartInfo_Common 414 No Disk Info detected for disk[0]
08-08-2021 10:24:09 INFO Home HOME::RequestDone 274 Update device information is completed.
Schöne Grüße
Rafal
Schöne Grüße
Rafal
