No sim Card Error A20E
m.
I bought new A20E in Mediamart Oberwart in September 2019, went well for a month and now every day there are about 10 times Error No Sim, I bought a new sim, tried Restore Factory setting and all other solutions, but sometimes comes a NO SIM card
No i did not try safe mode, but when i want to try safe mode offcourse i have to restart fone and when i restart it ll not give error for a few hours so how long should i keep safe mode ? and i have not many apps in fone.
Hello L: @malik8808,
could you find a solution yet? If not, please contact my colleagues from the technical support team. Their number is 06196 77 555 77.
Kind regards,
Thank you for your response. yes i still have this problem. Please send me phone number with country code.
Thanks
in which country do you live? Because the number I gave you is the German Samsung Support (+49 6196 77 555 77). If you prefer contacting the support of your own country, you can choose from this list:
Samsung: Locations
Hi there, is the SIM / SD Card holder of your Samsung Galaxy S7 also not levelly? Mine sticks out a bit and the gap size betwwen it and the housing of the phone is uneven too. What is your opinion on this and do you think I should return my phone? Only got it 2 weeks ago. Cheers Erik...
Hi Everyone,I bought a new Tab and water went inside it but very little and put it in rice for 2 days but still it doesn't even open and there is no responseWhat should i do? 4376413
I just bought my samsung galaxy book 750. I was using it and the screen went black. I have even plugged it in for charging but there is no sign of charging. No lights are blinking and its completely dead. I have already tried the volume + power button method. 4519816
Hi all, I bought Galaxy S9 last year, now I moved back to my home country. When I insert local SIM card on my phone, it does not make a phone call. other functions are working well, search as Data, SMS and others, Only not Phone call. I tried to find other options in the setting but never...
Hello, I apologise that I'm writing in english but it is easier for me to explain the problem. I have a frustrating issue with my phone. I bought Samsung S23 as a brand new around 3 months ago. It was working fine till last week - I started to have problems with the signal connetion - the...
