Problems after Android 13 UI. 5 Update
J.
Memory and Alarm Problems After my phone S21FE updated to UI 5 ANDROID 13...I've set the alarm on my phone at 5.30am, turned on Airplane mode and go to sleep.The next day I woke up at 8.30 with missing alarm, *1f614.png* and phone showing Memory Full... Also WhatsApp was frozen because the ''full memory'' (but it has 100gb free)...I've opened My Files *1f4c2.png* folder and the Internal memory icon was showing [0B/0B].I've restarted the phone, and then it was everything fine.Two days later, it was the same thing.... I need to mention that the phone was working fine till this Android 13 update.
How to make a wipe Cash Partition and repair apps: Turn off your phone》Connect the device to a PC/TV with a charging cable》Press and hold the power button + volume up button simultaneously until a menu appears》Use the volume up/down buttons to navigate to the item "Wipe Cache Partition"》 Confirm with the power button》Navigate to "Yes" in the submenu and confirm》After the process is complete, navigate to "Repair Apps"》Confirm with the power button and let the phone boot up
This process just wipes out leftovers from the old operating system and cleans up system junk. In addition, apps are readjusted to the system. Personal data is not lost in the process.
Either you wait for a new update bug fix
Or like I did when I had the same problem
on my s10 october update. Factory reset your s21 fe. This resolves most software conflicts. Before that, I recommend backing up your data with Smart Switch and Samsung Cloud.
Hello guys,I've recently updated my Galaxy phone to the new Android 12 version and I've immediately felt a big change in the vibration, it feels cheep and it's way louder than before.Is it just my phone or someone else is having the same experience? 4357959
Problem: Apps are crashing soon after opening. I have tried all possible ways with the Samsung agent on the phone but nothing worked. It was also advised by the agent that I should try to do a factory reset but due to the number of apps and the effort to install them again, I do not want to try...
Hi folks, I would like to ask if any of you has the same problem as I do with S21 ultra.I've been using my phone for about a year now without having a problem on daily base.Never played games as much or some other apps that do drain the battery, so just normal usage like social media and...
Y
Hai I been using Samsung S21 Ultra since February and have been facing two issues with the phone. 1) (The main and most frustrating thing) Grainy vedio capture in low to indoor condition. The vedio is grainy like a budget smartphone infact my realme 6 pro capture bettwe vedio indoor. I am not...
Hello community, I've had my phone since February this year. Battery life has gone really bad in the last month or so. I need a full barrel charge for 4 hours screen time, mainly social media. Compared to 10 hours before. I do optimize my apps, phone, brightness and so on. But still battery now...
