QE55Q7F VS QE55Q8F
J.
Is there a something ohter on the
QE55Q7F VS QE55Q8F
Please answer
Becous i find nothing
Hallo JurgenDP / Hello JurgenDP,
hat dir der Hinweis von andy-64 geholfen? / Is the reply by andy-64 helpful for you?
In einer Nussschale die wichtigsten Unterschiede / In a nutshell the most important differences:
  • Die Rückwände: Q8F silbernes Metall und Q7F schwarze Kunststoffrückwand / The rear panels: Q8F silver metal and Q7F black plastic
  • Unterschiedlicher Standfuß / Different foot
  • Verschiedene Lautsprecher. Q8F mit 60 Watt und der Q7F mit 40 Watt / Different speaker. Q8F with 60 watt and Q7F with 40 watt
Hi I am asking here, because I dont know where to ask anymore. I have run against an invisible wall of the german support. Here is my story. My 65JS9580 developed a dark spot in the panel and also sometimes was not able to turn on anymore unless I pulled the plug for a short period of time. No...
Deutsch: Hallo! Seit ein paar Wochen nun wird mein Smart hub immer langsamer. Zuvor musste ich oft 30-30 Sekunden warten bis die apps geladen wurden und ich etwas auswählen konnte (auch die Einstellungen z.b.). Seit gestern nun scheint das ganze Menü vollkommen aufgehangen zu sein. Wenn ich die...
Hello to everyone. short and simple. I have bought the Samsung Crystal UHD 4K TV 55 Inch (GU55AU7179UXZG). It works well, I can also connect with my phone without a problem. The TV is connected to wireless. the problem is: if I turn on the TV back and forth I just hear the tone, but not the...
Since a few weeks, almost all the apps on my A52s 5G prompt a message after just a few minutes of normal usage that there is no Internet connection (or something of the like), or the apps stop working/refreshing. At first, I thought this was an issue with Meta apps (Insta, WhatsApp, etc.). But...
I bought 1 x 55" QLED 4K Q60B (2022) from corporate benefits website on 31/10/2022, but still waiting for deliver I called the call center 5 times, they are just saying they deal with it or they open ticket but nothing is happenning I want my product in fastest way, otherwise payback to me...
