QN94A 55" flicker / dimming problem
R.
Hello. I have a UK QN94A as I am from the UK. I have a problem with the TV and I'm on FW 1903. I don't know who to tell my problem to. My issue only happens in Movie mode / Filmmaker mode... After switching to the Nvidea Geforce driver-update web-page on the browser on my PC (which is a true-black background with white highlights as well as greens and grays) it will fluctuate / flicker bright-dark-bright-dark-bright -dark-bright quickly for 2 to 3 seconds. It's worse when you switch from a bright screen to that web-page. If you spend longer than 5 seconds, and worse, more than 10 seconds on a bright screen such as Windows 11 Update then immediately open the Nvidea web-page then it's like the software can't decide what brightness to display the Nvidea page at so the entire screen alternates between darker / brighter several times for several seconds before settling. It's obvious and not very subtle when it happens. Even when switching tabs on the browser from a pale web-page to the Nvidea driver page it will happen.
Please help me with my problem. thanks
I know it is a UK model but I thought they use the same firmware and the hardware is the same? I thought the German expert here could tell the engineer about the issue and maybe improve the 1904 patch. I know maybe I should not post on the German forum but I honestly am half-German! I'm sorry but my German language skills are not good enough to tell my problem and most Germans speak good English. I'm sorry if I have made you angry.
Can you delete posts here? I cannot see how to! By mistake I posted the same thing twice.
I like Movie mode so I use it for my PC. I have tried all the other modes and my problem is only with Movie mode and Filmmaker mode. Normally it's OK but it doesn't work properly with black-screens with bright highlights such as the Nvidea driver-update web page... If you switch to that page after being on a bright screen it goes crazy for 2 to 3 seconds like I fully described in the original post.
the picture on my tv randomly darkens when playing video games on the pc, if I then go to the settings in dimming from low to standard the brightness is back to normal - I know that was an old problem but with me it is only since the new update before I never had it. and it also happens in...
After installation of Firmware 1392 on my Frame 49 (Modelcode: QE49LS03RAUXZG) I have huge HDMI sync problems. Everytime when I move a running Windows 11 Window on this Frame as an external monitor the HDMI sync crashes. Most of the time, the resync happens after ~5 sec. It is not possible to...
Hi, I am an artist producing artworks involving a computer and a vertical The Frame display. To make my art installation nicer for the end user, I want that the only user interaction is one touch on the computer power button. The computer turns on, sends a WakeOnLan signal to the TV which turns...
PIP Funktion: Ich denke die meisten Nutzer wollen PIP dafür benutzen, um bei Werbeunterbrechungen zu sehen wann Sie zurückschalten sollen. Dafür ist die aktuelle Funktion sehr ungenügend. Es wäre toll beim nächsten Update folgende Möglichkeiten vorzusehen: Beim PIP Anschalten den aktuellen...
Hi I am asking here, because I dont know where to ask anymore. I have run against an invisible wall of the german support. Here is my story. My 65JS9580 developed a dark spot in the panel and also sometimes was not able to turn on anymore unless I pulled the plug for a short period of time. No...
