Repair apps no longer works on one ui6
s.
Today, my s23 Ultra receives the one ui 6 final update. After the update I started the wipe cache command and the repair apps command from the boot menu, but the later doesn't show progress or any sign of cleaning the apps.
The hidden system partition is now more than 10 GB in size. The repair apps option was the only way in reducing this temp data, if you won't reset your phone every year.
Habe das Problem auch und einen Fehlerbericht erstellt. Mach du das auch, damit Samsung das fixt.
At least the system storage partition is much tiny now, one ui 5 was almost 100gb now is with system and hidden system together just around 28gb
For me there is more to be happy then worried about it *m:1f60a.png*
I am using Samsung S9. Its only 6 months & so many defects.. 1. FAST CHARGING doesn't work. 2. Battery drain very fast. 3. USB data transfer doesn't work. I send the device to service center of Telekom. They returned without repair & asking me to buy a new one.. The reason was water defect...
I got my long waited S22 Ultra yesterday after more that 5 weeks of waiting. Unfortunately I don't have yet the USB C dock charger so I used the old one to charge it. Today I connect it to my laptop with the USB C cable provided in the box, surprise!!! the cable works only on the "charging port"...
