S6 edge don't boot up
I have an s6 edge. My cousin was watching video. Suddenly it turned off because of no battery charge left. I put it on charge. After full charge it didn't turn on. I have tried by power, volume button, nothing worked. When i try to turn on only Notification light is on thats all.
Any advice or suggestions will be really helpful. Thanks
Vielleicht ist da nach der langen Zeit einfach irgendwas kaputt gegangen. Das hat ja inzwischen auch viele Jahre hinter sich.
Im einfachsten Fall wird die Batterie kaputt sein.
Im schlimmsten Fall jedoch Sachen, die man eher nicht reparieren kann (Motherboard als Beispiel)
Hello, I was using my Galaxy Active watch for 2 years and it worked perfectly. Then it received an update, and last thing i saw in the watch was something like "Now you can use Samsung Pay, check your phone to continue with the update". I had not time to proceed and complete the update, and the...
Hello people. I got some cheap headphone jack and everytime I connect it to my device it tells me to turn Google Assistant on for assistance. I don't want to use Google Assistant and have turned it off but it keeps asking me every time I connect the dongle. Is there a way I can stop that? Or is...
Hello dear Samsung users, I have a problem when I want to open a video in my gallery I am redirected to the video player and have no choice but to watch it on the video player. But I want to watch my videos in the gallery app because I want to I don't think the video player is suitable for my...
Ok so I have been using the S10 Lite for a bit over 3 years now, and even after I dropped my first one into the water (spoiler it didn't survive causd it's not api aproved) I bought the same phone again. But I recently realized that the backcover which is made out of "GLASTIC" is extremly weak...
Q
I just bought two t7 ssds from samsung. I booted them up on my laptop, put some files on them to transfer to my pc at home etc. All worked fine. I also installed the samsung SSD Software on the Laptop and PC. The SSD is being detected by said software on both machines. I turned of the password...
