Samsung Glue Problem
c.
So i use my tablet ( Tab A8 ) alot but in my Home its very warm so sadly, the glue of the Display melted and i need to press on my Display to hold the glue (Its only on the right side in the corner, The same Happned to my Samsung J6+ the back Glue melted and the back completly falls off so i put tape on it to hold, I bought myself a new phone The Samsung Galaxy A10 and im Very Exited to open it when its at my house (i ordered online) But still, Samsung makes the best phones!
then maybe think about to reduce the warmth in your home....
then the issues with the glue should vanish quickly.
*1f618.png*
constant temperatures over 30°C are not good for the glued components L: Lösung in ursprünglichem Beitrag anzeigen
*1f618.png*
I have the same issue with my tab s8 Ultra. The camera side of the dispaly sometimes lifts itseld for less than 1mm, but can be pressed back and stays in the correct position for a few days/ weeks.
Maybe happened because of sunlight exposure.
I Heard that Temperatures over 30°C or over is Not good for the glue but my Display holds only for a few minuts or hours probably bcs some dust came in
Guys, whats going on here, my tab s8 ultra after update on UI5.1 every minute pass the battery goes down. As you can see from the screen picture i always charge the tablet until 85% and i use it until max 20% and today this happening. In 60Hz, flightmode, wifi on, low brightness, nightshift...
Hi*, my Lenovo Tab 4 8 is giving up and I want to reuse my old Galaxy Tab 2 (GT5100) but I need to update it from Android 4.0.someting to the latest 4.2.2 (I assume it was the latest) Where can I find it)? Thanks in advance 5506917
I bought my s7 tablet last year and pen is damaged now.. How can i change the tip? Can i claim warranty on it or have to buy from third party? 6230488
So ever since the last update the physical keyboard layout has switche and the keys for ü, ä and ö now print out [, ' and ; instead. I tried to change every kind of laguage setting which could have an effect on this but it didn't change anything. Then after some research I Found that reseting...
Hallo, Ich habe das Samsung Galaxy S5e Cover im österreichischen Shop bestellt, weil es in Slowenien kein Cover gab und ich es nicht bekommen habe. Der Track-Item-Button leitet zur TNT-Seite weiter, auf der meine Bestellung ursprünglich für den 09.05.2013 geplant war. Meine Adresse war korrekt...
