Samsung pay open automatically
Hello, I have Samsung galaxy watch 3 , and from 2 weeks ago, the Samsung pay open automatically every 2 seconds, that is so silly , anyone know what the solution for this problem??
Dear all, For last two week, post android update, my phone A40 is getting switched off automatically...I switch on the phone every time....I bought the phone 2 years before.... Request your help 3333297
Hello, I was using my Galaxy Active watch for 2 years and it worked perfectly. Then it received an update, and last thing i saw in the watch was something like "Now you can use Samsung Pay, check your phone to continue with the update". I had not time to proceed and complete the update, and the...
Hello I have a problem with my left Bud if I connect it over bluetooth with ay device it makes an annoying beep pause beep tone. After the problem orccured I gave it a neat clean which fixed the problem for about a minute after that it started beeping. I suspect some kind of loose contact inside...
Hello Samsung Community, Does anyone of you know whether the old watches like Active 2 and Watch 3 will also get the new Wear OS or whether they will stay on Tizen?And will they then get updates or not ? 3447157
So every time I open/close the phone Bluetooth turns off for a few seconds and then turns on again. But why does it do that? 7879558
