Samsung s23 ultra one ui 6 - network problem
J.
After having upgraded the S23 Ultra to android 14 and one ui 6.0 I'm having big connectivity and battery problems. The reception is bad, absent or at most a notch and the people I call can't hear me! Even the internet connection it's of course not there.
I tried to switch the sim to a Samsung A10 and it can perform the calls well (a 150€ phone!).
After the update even the battery it's draining quite more even if the behavior it's the same!
This is absolutely unacceptable for a phone of this price! I was happy until I upgraded, worst error I did.
Hast Du das vielleicht mal an Samsung kommuniziert? Was hast Du denn schon unternommen um den Fehler zu beheben?
Have you already tried the following? Could be helpful. *m:270c.png**m:1f603.png*
The final step, which should also be carried out after every system update/initial setup, would be to run the options “Wipe Cache Partition” and then “Repair Apps” in recovery mode.
To do this, switch off the smartphone. Connect to the running PC/notebook/game console/USB connection TV using a USB-C cable.
Simultaneously press and hold the power button and the volume up buttons on the smartphone until the logo appears and recovery mode starts.
There select the options above. Control with the volume up and down buttons and select and confirm execution with the power button.
With these measures you can remove junk data from your smartphone that can lead to malfunctions.
Care should be taken when executing these functions as an incorrect option may result in data loss.
If you want to monitor and optimize your smartphone even better, I recommend the Samsung Good Guardians Tools. Been using it since it came out.
Good Guardians - the new name of Galaxy Labs - Applications sur le Galaxy Store
https://eu.community.samsung.com/t5/mobile-apps-services/samsung-quot-good-guardians-quot-toolsammlu...
Hey, I recently upgraded to an S23+ from my old S10e. However, when comparing the two phone's cameras, I noticed, that the photos of my S10e contain noticeably more details when zooming into the photo. And when looking at the details of the photo, the resolution of my S10e is also slightly...
Hello, I apologise that I'm writing in english but it is easier for me to explain the problem. I have a frustrating issue with my phone. I bought Samsung S23 as a brand new around 3 months ago. It was working fine till last week - I started to have problems with the signal connetion - the...
The Samsung Galaxy S23 Ultra offers an impressive feature: fingerprint sensor activation. This new option allows users to activate their device even faster and more securely. As soon as a finger is placed on the sensor integrated into the display, the smartphone is unlocked and turned on –...
Hello there. Hope everyone is doing fine. My order for the S23 Ultra has been canceled by my brother while doing a joke. I have received the phone and of course I wanna keep it as I have ordered it. So my question is: How can I cancel the return process? (As I said, I already have the phone and...
Hallo, mein brandneues S23 scheint wohl auf qcc.qualcomm.com zuzugreifen. Wenn ich dazu suche finde ich folgendes: QCC on Samsung's Processor. what is qcc on samsungs system process "QCC" on Samsung's system process likely refers to "Quick Command Chain", which is a...
