samsung screen shot is broken on s23 ultra
g.
Hi.
I have a new s23 ultra and screen shot / screen capture is broken.
all samsung articles how to do a screen shot refer to pressing vol.down and function button at the same time, but my phone only shows the restart/shutdown dialog...
also there is no app smasung capture, or screen shot.... nothing. i also cant install it from samsung shop.
why is it not there? what am i supposed to do, take another phone and photograph my screen?
Das ist eine Grundfunktion ohne App. Du darfst die Tasten nur sehr kurz zusammen drücken. Funktioniert bei meinem S23 Ultra problemlos.
To take a screenshot, you can also swipe the edge of your hand across the display if this feature is enabled under Gestures. L: Lösung in ursprünglichem Beitrag anzeigen
Barney said only press the button combo short.
There also a swipe gesture to do it. Google how to do or search in settings.
finally you can use a quick setting. if it's not yet in the quick panel, add it. L: Lösung in ursprünglichem Beitrag anzeigen
Hello there. Hope everyone is doing fine. My order for the S23 Ultra has been canceled by my brother while doing a joke. I have received the phone and of course I wanna keep it as I have ordered it. So my question is: How can I cancel the return process? (As I said, I already have the phone and...
It's possible that the screen is broken after a 20cm fall?? In a device that cost only 800€!!Broken after a month! Ah and dont forget the 60€ for the led cover, beautiful nothing to say, but if it open when fall what must protect?? Now if you can tell me what is the best way to get it repaired...
After having upgraded the S23 Ultra to android 14 and one ui 6.0 I'm having big connectivity and battery problems. The reception is bad, absent or at most a notch and the people I call can't hear me! Even the internet connection it's of course not there.  I tried to switch the sim to a Samsung...
Hello, I apologise that I'm writing in english but it is easier for me to explain the problem. I have a frustrating issue with my phone. I bought Samsung S23 as a brand new around 3 months ago. It was working fine till last week - I started to have problems with the signal connetion - the...
Hey, I recently upgraded to an S23+ from my old S10e. However, when comparing the two phone's cameras, I noticed, that the photos of my S10e contain noticeably more details when zooming into the photo. And when looking at the details of the photo, the resolution of my S10e is also slightly...
