Samsung TV: Schwarzer Bildschirm nach 3 Tagen - Hilfe gesucht!
Hi! I just turned on my Samsung TV and the schreen doesn't work. It's black. I bought it 3 days ago.
The only thing I can hear it's a small sound.
Can someone help me?
  • Samsung TV Modell herausfinden: So geht´s
    Samsung TV Modell herausfinden: So geht´sUm das Modell Ihres Samsung-Fernsehers herauszufinden, gibt es mehrere Möglichkeiten. Am einfachsten ist es, wenn Sie die Einstellungen im Menü des Fernsehers aufrufen.
Was hörst du denn genau? Trenne das Gerät mal 10 min vom Strom.
Sonst einen Hardreset machen....
Falls du nach dem Hardreset fragen willst :
TV Modell und Google :great:
It's a sound every 10 seconds, I can't explain the sound :rofl:
How can I do the hardest?
Hello to everyone. short and simple. I have bought the Samsung Crystal UHD 4K TV 55 Inch (GU55AU7179UXZG). It works well, I can also connect with my phone without a problem. The TV is connected to wireless. the problem is: if I turn on the TV back and forth I just hear the tone, but not the...
Dear customer care team. I bought my Samsung Qled Q6FN TV 2 days ago and since I turned on - loading apps show (loading apps) for a sec and nothing happened. - when I use search I can look for an application but when I go to the app - I reset smart hub several times and it did not work. - I...
Hello. I have a UK QN94A as I am from the UK. I have a problem with the TV and I'm on FW 1903. I don't know who to tell my problem to. My issue only happens in Movie mode / Filmmaker mode... After switching to the Nvidea Geforce driver-update web-page on the browser on my PC (which is a...
Hi, this is probably a very thumb question, but my TV (GQ43LS03TAUXZG) does some kind of sound processing when using Bluetooth for output. It seems like it has some kind of limiter which lowers the volume whenever the signal gets louder, which makes it absolutely impossible to hear music but is...
I have a Samsung Galaxy A51 with Android 11. I bought it about a bit less than a year ago I think and I use old Samsung headphones (wired, not Bluetooth) from an older phone. They never caused any problems. But since a few months, every time I plug in my headphones, after a few minutes, my...
