Slow motion video comes so worse.
P.
I am using Samsung A52s 5g. When I record slow motion videos, the video comes with fully blurred and with very low quality. 64mp camera works fine but this is very much disappointing. #A52s #SamsungA52s, #Slowmotion, #Camera, #Quality
  • TikTok: Verlauf ansehen – so gehts
    TikTok: Verlauf ansehen – so gehtsTikTok ist überfüllt mit angenehmen, anregenden, humorvollen und spannenden Videos. Wenn dir ein bestimmtes Video besonders gut gefallen hat, du aber nicht...
So do you need any help or did you just wanted to share your expirience?*1f62c.png*
It is known recording in Slowmotion is a lower quality. You can't compare it with "normal" Videos in 4k or Full HD.
Still a minimum quality should be there right? Camera always goes out of focus and its too blurry. I use other phones as well and slow motion videos are very much better. This is like very poor
I just wanted to know if anything I can do to fix it. Maybe a change in settings or something like that ..
When you think it could be a Hardware problem please contact the Samsung support.
Also important for better quality is the light. Recording with daylight is much better than in the dark.
Reseting camera settings is a further option.
When I make the slow motion video it looks very amazing but after I post it on my TikTok account it looks very worst kindlyguide me about it.
Hi everyone, -Is standard video better than pro video on Samsung galaxy s20? I tried to change parameters like ISO, and speed on pro video. But pro video's quality is still worse than standard video. Does anyone know why there is that difference? Because I could not see the parameter in standard...
Hello Samsung community, I recently noticed that my Samsung S21 is not able to record loud music properly. When I go to discos/Pubs/Festivals with loud music and record a video, the device distorts the bass. My device works perfectly and I use it with no case. This is strange since I didn't have...
I've got a Samsung S8+ and I don't want to ring out all people arround me only because of that I am very often in a very loud place. So I want to get it working in the way that it starts with a low ring and increases this over an adjustable time to a high ring. If I would programm it I would do...
Hello, I will write in english it will be easeir for everyone. Almost one month ago I bought this phone, and so far I encountered following problems with it: Front and back cameras got huge problems with focusing, especially front one. Front camera cant focus at all, its forced to keep...
I just bought this phone 2 weeks ago and been using the s pen to draw eversince. Earlier yesterday, i used it and it works fine.. it stayed inside the phone when i put it back. But later on the same day when i use it again, and put it back.. somehow it won't stay inside. It's very loose. I...
