Tv
B.
I'm living in germany and I want to watch samsung tv plus in english how can I change my language settings on the tv to English and does that mean the movies will play in english.
  • HbbTV - was ist das?
Das ging bisher nicht, da musstest Du ein Smartphone aus GB nutzen. Das ließ sich auch nicht einstellen. In Deutschland stehen meines Wissens nur deutsche Programme zur Verfügung.
Sorry schau mal bitte in den Screenshot, das ist in den Einstellungen zu finden. Vielleicht hilft das ja inzwischen. Das ist bei Samsung Free Watch zu finden.
How do I change the region or language when using Samsung TV plus? 8637525
In the settings I have the option to use English from different cuntries. I'm a german and I'm curious if there is a difference between English from the UK and the German version? 5978369
Hi, I am an artist producing artworks involving a computer and a vertical The Frame display. To make my art installation nicer for the end user, I want that the only user interaction is one touch on the computer power button. The computer turns on, sends a WakeOnLan signal to the TV which turns...
I bought 1 x 55" QLED 4K Q60B (2022) from corporate benefits website on 31/10/2022, but still waiting for deliver I called the call center 5 times, they are just saying they deal with it or they open ticket but nothing is happenning I want my product in fastest way, otherwise payback to me...
the picture on my tv randomly darkens when playing video games on the pc, if I then go to the settings in dimming from low to standard the brightness is back to normal - I know that was an old problem but with me it is only since the new update before I never had it. and it also happens in...
