Unknown System network activity
P.
Hallo, mein brandneues S23 scheint wohl auf qcc.qualcomm.com zuzugreifen.
Wenn ich dazu suche finde ich folgendes:
QCC on Samsung's Processor.
what is qcc on samsungs system process "QCC" on Samsung's system process likely refers to "Quick Command Chain", which is a technology used in Samsung's Exynos processors. Quick Command Chain is a feature that helps improve the speed and efficiency of complex computing tasks by reducing the latency and increasing the bandwidth of communication between different processing units within the processor.
Essentially, Quick Command Chain enables faster and more efficient data transfer between different components of the processor, which can result in better overall performance for the device. This technology is especially useful for applications that require a lot of processing power, such as high-end gaming, video editing, or machine learning.
It's worth noting that Quick Command Chain is a proprietary technology developed by Samsung and is not found in all processors or devices.
~chatgpt ftw.
Meine erste Frage ist es korrekt und meine zweite wäre, warum kommuniziert ein Systemprozess, welches den verbauten Prozessor dient ins Internet? Das finde ich überaus Heikel, Sicherheitstechnisch gesehen. Daher würde ich wenigstens wissen, warum und ob ich ohne Verluste den Netzzugriff blockieren kann.
    The back swipe gesture isnt working sometimes on Facebook, and as an always Samsung fan, please improve the responsiveness of bottom swipe gesture and also the quick panel its not smooth sometimes i need to touch more than once the bottom swipe gesture to move the quick panel back. This is so...
    Hello people. I got some cheap headphone jack and everytime I connect it to my device it tells me to turn Google Assistant on for assistance. I don't want to use Google Assistant and have turned it off but it keeps asking me every time I connect the dongle. Is there a way I can stop that? Or is...
    I am using S23ultra and it's a bad feeling to see that it is not smooth as it should be, for instance every time I open Galaxy store for apps or update it lags the UI isn't fluid unlike google playstore which feels better to open and use.  Do you guys feel the same ?????? I totally love my...
    - Add the possibility to insert a white sp[ace between text and paragraphs in notes- the header that contains the name of the file is really huge! while all this space is taken? its better to reuse the header that is in "write on a pdf" or skwtch apps from samsung too. the header in samsung...
    I got the following issues with the S23Ultra camera app, but it wont do much good if I'm the only person requesting, so if you find my proposals useful, maybe drop them an email too. 1: Autofocus in Pro Mode seems unreliable, I had my phone on a stand then stepping in front of it and the AF...
