Upgrading to Android 12
G.
I am trying to update my android 11 to the new version 12, while living in Germany. I am using a S10 but not getting update (where it says the phone is up to date), but all other S10s in Germany recieved the update.I had bought the phone in Belgium and used it in Afghanistan in the past.
This is what I get when I try to update:Your software is up to date. Software update information • Current version: G973FXXSEFUL1 / G973FOXMEFUJ2 / G973FXXSEFUJ2
Can someone please let me know how to update my phone?
  • Android: Screen Mirroring
You can try and update the phone via SmartSwitch. You need to connect it with your computer and install SmartSwitch on the pc.
I don't know the status for the Android 12 update in Belgium.
If the update is available in belgium you will get it to your device. It's because you boght it from there.
ein downgrade auf Android 11 ist auf legalem Weg nicht möglich
Sadly SmartSwitch also shows that the device is up to date.
What could be the next approach?
I guess the only thing is left is to wait for the Android 12 release in belgium
Well after checking my CSC code, it seems that since I last updated the firmware in Afghanistan (AFG), I have to wait for an update in there.
Is there any other way to switch my firmware other than flashing the phone through ODIN?
Hey, i have a broken Galaxy S10e display. The upper 0.5cm of the display are still working, and the phone itself too. I have saved my data on a PC via the findmymobile app to the samsung cloud, but somehow the option to save pictures from the gallery is not available. How can i save pictures...
Ok so I have been using the S10 Lite for a bit over 3 years now, and even after I dropped my first one into the water (spoiler it didn't survive causd it's not api aproved) I bought the same phone again. But I recently realized that the backcover which is made out of "GLASTIC" is extremly weak...
Q
Hello everyone, i live in Austria but my german is not good enough for this complicated posts. I bought my galaxy s10e today from A1 with a contract and as soon as i started it i was barely able to hold it in my hands. Then i downloaded an app which measures battery temperature and after...
Hallo sir ,Iam using Samsung Galaxy s10 plus for 2 years, it's working good but now I have a problem with Updateing my phone is still in one ui 2.0 and it's not going to bring new updates, I have try everything what I know and what I have saw in YouTube but nan of them work .And my phone camera...
I just bought this phone 2 weeks ago and been using the s pen to draw eversince. Earlier yesterday, i used it and it works fine.. it stayed inside the phone when i put it back. But later on the same day when i use it again, and put it back.. somehow it won't stay inside. It's very loose. I...
