USB-C Charging Issue
j.
Hello,
since two weeks I’m not able to charge my phone via an USB-C charger. If I charge it via normal USB it works - but slow.
I thought the issue comes from the USB connector module, but after replacing it I still face the same issue.
Basically, any charging device with USB-C exit does not work, only the old ones with USB (fixed 5V).
Any ideas what could be the issue?
Also, sometimes I get the waring that charging stopped because of overheat – although this message comes directly after connecting it, and it is definitely not hot.
(Phone is up to date with all updates)
BR
    Hi, sounds like you have a big hardware problem. Or you use the wrong USB charging device, is it the stock one?
    Have you try to reset the phone completely, to take out that this maybe a software issues?
    I'm not sure but I remember in the past same problems with overheating, that is coming from a damaging of the processors who cares the batterie cells. It's like a safety system, it can be after a hard reset and wipe cache partition cleaning, that the normal regulators will work again. Hope you can get a good solution after. Good luck.
    Did your phone come with an original USB charger for your device?
    Does charging with such original charger work?
    At which level of battery charge are you making your observations?
    Did you change the configuration for charging or did you keep the default configuration?
    I don't know which model you have. And I never had a Samsung device of any S-series. I've a model of an A-series, probably almost as old as your unnamed model. So my configuration options may be more limited than yours. I used default configuration for a long time. Only recently, I activated a protection option to limit charging up to 85%. Some more months ago, I replaced the cable for charging, but continue to use the original charging device. The original cable had a problematic form. That form made it more critical for break of isolation and cable, especially close to the most vulnerable location of the cable. At least several isolations were breaking at expected location. So now I've less issues as the new 3rd party cable of conventional form is working more reliably and without such mechanical vulnerability.
    If you want to use a 3rd party charger, you've to check for compatibility. Notes on the original charger may help finding good candidates. An incomatible one may be limited to slow charging, if charging at all.
    Hello,
    thanks for your response!
    I’m using the charger which came with the phone, also I tried different cables and charges. With the Galaxy S21 of my friend everything works fine. So my phone is the issue.
    I don’t think it is true overheating. This warning comes only from time to time right after connecting. I rather think it is a broken sensor, connection or SW issue.
    After disconnecting and connection it works again.
    But as I said, it only charges using an 5V charger (or power bank). And using that it takes around 6h to charge.
    I will try a reset, although it is a pain in the ass *::face-with-stuck-out-tongue-and-winking-eye:
    BR
    Hello,
    It’s a Galaxy S20 5G
    I’m using the charger which came with the phone, also I tried different cables and charges. With the Galaxy S21 of my friend everything works fine. So, my phone is the issue.
    The issue comes at any level of battery.
    All settings are at default regarding the charging options (everything is activated).
    BR
    German (Google Translate, sorry): Ich kaufte mein Galaxy S8 am 27. September. Immer wenn ich mein Ladegerät anschließe (original Samsung "Adaptive Fast Charging") schaltet der Stutus des Gerätes zwischen Aufladen und Nichtladen alle paar Sekunden um. Ich muss das Ladegerät mehrfach trennen und...
    I am having problem with my WhatsApp Notification since I updated my phone to the new Samsung software. I am not getting a pop up message on my phone. It is stated that the "pop up style " does not work on the new software. What do I do. Any help? 6562985
    I have 2 problems with my new Galaxy S20+ 5G: 1) for long conversations and the use of the "Mute" function. Because of my work, I have 1 or 2 hours of phone sessions and use my phone to call when I use the call "mute" and leave it for more than 30 minutes, later, if I want to turn off the mute...
    Hi folks, I would like to ask if any of you has the same problem as I do with S21 ultra.I've been using my phone for about a year now without having a problem on daily base.Never played games as much or some other apps that do drain the battery, so just normal usage like social media and...
    My name is utkarsh modi and I am really sorry if I will be use harsh word but this is really serious issue . I am really disappointed with your phone quality and customer service. I purchased a Samsung s20+ phone in November 2020. As a first purchased with Samsung I was really cared about my...
