Why does my battery drain so fast?
Wahrscheinlich weil das Smartphone älter ist und der Akku defekt ist.
Mach doch mal einen Wipe Cache und Repair Apps im Recovery Menü.
Have you already set the apps to deep standby in the device maintenance app?
Guys, whats going on here, my tab s8 ultra after update on UI5.1 every minute pass the battery goes down. As you can see from the screen picture i always charge the tablet until 85% and i use it until max 20% and today this happening. In 60Hz, flightmode, wifi on, low brightness, nightshift...
I am using Samsung S9. Its only 6 months & so many defects.. 1. FAST CHARGING doesn't work. 2. Battery drain very fast. 3. USB data transfer doesn't work. I send the device to service center of Telekom. They returned without repair & asking me to buy a new one.. The reason was water defect...
Is it normal that my battery drains this quickly over a normal day? I'm not even a hard-core user? Like samsung what are u guys doing. This phone is 4 months old and was brand new. How could someone consider this a flagship phone??? I could buy an iPhone from 4 years ago and it would have a...
I have a charger that supports the super fast charging on my S20 FE 5G but when i try to charge my S9 plus it doesnt charge at all. Not even normal. Does anyone know what the reason could be? 4202750
On 05.12.2023 I updated to Android 14 using OTA. and everything went as it should. But after install I noticed fast battery drain and the phone display is hot to the touch even while i'm writing here, when i listen to the music using BT earphones the display is also hot even if it's off. I read...
