Why does my phone not have all options?
N.
Hello dear readers,
Today I saw that my friend has more edge lightning options than me (See photo). I have the Samsung Galaxy A54 5G phone which was released on may this year
My friend has way more options, and I wanted to ask you: do you also have only these like me or do you have more? Is there a way to get more options?
Thanks!
I think that the galaxy A versions don't have the last one because I have one too
Denke mal es ist Handy abhängig. Wenn bei Dir nicht mehr ist, dann ist es leider so.
Das ist doch normal das die A-Klasse nicht sämtliche Funktionen der Topmodelle spendiert bekommt. Das war noch nie anders.
Yeah this is the problem because the A versions don't have this one thing like the S versions
Hello, I inserted a 64 GB micro sd card into my Galaxy A 52 and I am able to view all the stored pictures and videos in my Gallery. I was also able to change the settings to save taken pictures directly to the SD card, so everything seems to work fine. However when I open 'samsung my files' it...
Hello Dear Community and Samsung Team, I have been using their smart phones for some time now. Now I wanted to use my all Samsung Galaxy S9 leader a scientific experiment. My goal is to drive a microcontroller with various transmitting devices for IoT applications via OTG now the question arises...
Hey, i have a broken Galaxy S10e display. The upper 0.5cm of the display are still working, and the phone itself too. I have saved my data on a PC via the findmymobile app to the samsung cloud, but somehow the option to save pictures from the gallery is not available. How can i save pictures...
Hello, i have recently bought Samsung galaxy watch 3 BT. I am using Note10+ . Now when i am trying to search for the wifi, it is able to search all the wifi around me expect my wifi. I tried resetting it but this hasn't solved my problem. Can you please guide me. Thank you. 2492057
Hi, i'm from Italy I have a S9 DUOS I contacted the Italian community but was told that the firmware I currently have installed should be the one released by Samsung Germany in January (but I bought the phone in Italy). Until January I have always received regular updates without problems. From...
