Wobble / lag / jitter / jump while scrolling
Hello,
I noticed something annoying with the Galaxy S21. When I scroll slowly in an app, you can see a wobble / lag / jitter / jump. I can reproduce the behavior on another S21 which has been reset. The behavior is also seen on an S10, which is not as extreme. It's not as noticeable if you don't know what to look for.
So you can see what I mean, I created a video. Pay attention to the button at the bottom right, which usually appears when you scroll backwards.
Screen_Recording_20210620-155243_Boost
*icon_media_content_video.jpg*L: (in "Meine Videos" anzeigen)
So I have the following questions:Is there any way to turn it off or reduce it?
What could be the cause?
Can't this be forwarded to a developer who can take a look at it?
I don't think it's appropriate for such an expensive device to have this kind of behavior.
Wende Dich doch bitte an den Support, über Samsung Members Hilfe holen. Hier ist eine Community, da kann keiner etwas an die Entwickler weiterleiten.
Treiben sich hier keine Mitarbeiter rum? Nichtsdestotrotz kann das Problem hier diskutiert werden. Vielleicht hat ja ein Nutzer das gleiche Problem gehabt und hat eventuell eine Lösung oder einen Ansatzpunkt.
Ich sehe auch, dass ich im deutschsprachigen Forum gelandet bin.
Its not the phone its the Website i have the same things
Hi, after few years of using another brand I decided to try the new s21 ultra, and I'm completely disappointed.. It's not normal when you have a phone who pretend to be the best from the best and you have 12gb ram and 256gb to have problems when you do a videocall and want after 10-15 minutes to...
I am with Samsung since the S2 I uses many versions of S and Note and even A but I always have a screen problem starting with S6 edge + and Note 8 and Note 9 and A 70 , a week ago I ordered the S21 ultra but I recieved the telephone with present inside, shake the telephone and you can hear...
How can i turn off the pasword requirement everytime i start restart the phone. It is there a way to turn it off? Thank you for your help. Wie kann ich abschalten das immer wenn ich mein Handy neu starte das Passwort für SecureFolder zu geben? Danke im voraus. 7765549
(Folgt für Deutsch einfach den Begriffen unten auf Deutsch. Ist ziemlich selbsterklärend.) I ran into the problem that my Epson L555 was not detected/ installed automatically. The solution in my case was rather simple. Go to settings (German: Einstellungen) go to connections (Verbindungen)...
Having a single device to cover all needs seams quite possible these days. Ofcourse i am speaking of dex, its moving in the right direction, not to say that it can use a bit of accelaration. Nevertheless a single device to work at an instance, play on demand and stay on the move, what else would...
