Problems with Camera because of Sun light - software or hardware problem!?
Dear community,
I just noticed that when I take a photo that includes sun light or sun light reflection on glasses/windows, I get yellow distortion in my photos I wonder, is this manufacturing issue? Or software? Or misusage? Have you faced this problem before and what are the solution?
Noticed the yellow distortion on the flag
Here is another example on the right, beside white pants
Thank you and looking forward to hearing your solutions!
Hello! MajittoKun.
I think thats a Softwareproblem. Because the sun is not so big on the Photo.
Make this 2 things:
1. Go to the camera app》 Hold the camera app》 on the small i at the top right》 Memory》 Empty cache and still delete data.
2. Switch off the mobile phone / tablet》 Connect to a PC / laptop / console with a charging cable》 Hold down the power button and the volume up button (+) for at least 5 seconds》 A so-called "Recovery Menu" appears》 There, please click once on "Wipe Cache Partition" " YES "》 And then click on" Repair Apps ".
Your mobile phone / tablet will be restarted and the apps will be optimized there (there is a box below after restarting)
__________________________
Distress:
You use the "Recovery Menu" with the volume up key = up and with the volume down key = down and confirm with the power key = YES.
_________
A wipe cache partition does not erase the data of your cell phone / tablet, it erases the garbage from the previous version!
_______
Many greetings, Sungur
This is normal. It always depends on the angle between the camera and the sun. Do what Sungur already said.
Das war schon immer so. Es ist nunmal so, wenn Du direkt gegen die Sonne fotografiert, dann erscheinen diese gelben Punkte.
Halte das Handy einfach etwas anderes und lasse nicht gerade die Sonne darauf scheinen.
Versteh Deine Frage überhaupt nicht. Schau auf das Haus. Es spiegelt voll die Sonne gegen die Scheibe.
Ist doch normal, das so was passiert. Du musst ja so nicht halten, und ändere dann den Winkel.
Yes I know a ray always shows from the sun, I use cameras since 15 years! But this yellow flare/distortion is not normal and should not appear
I know the flare and sun rays , my problem is something different, it is a distortion and should not appear
Hello, I will write in english it will be easeir for everyone. Almost one month ago I bought this phone, and so far I encountered following problems with it: Front and back cameras got huge problems with focusing, especially front one. Front camera cant focus at all, its forced to keep...
Dear Samsung / Dear Community,  I have been doing some research on this topic and only find discussion about encryption basics, like if SW or HW encryption is better. But I feel like my question is something for real IT-Pro's so I try my luck here. Please only answer / give advice if you have...
Hello everyone, I just received today my Galaxy Book Flex2 i7 and I have two concerns that I would like to know whether they are normal or I have had bad luck and got a defect device: 1. The touchpad click is triggering a "rattling sound" as if some keys on the keyboard were loose. The left...
I was super excited when my S24Ultra arrived. It feels luxurious, but quite big for my smaller hands but that's alright.  It has many functions that are amazing and the AI functions are crazy and impressive. What really disappointed me was the camera. I had very HIGH expectations for this one...
I got the following issues with the S23Ultra camera app, but it wont do much good if I'm the only person requesting, so if you find my proposals useful, maybe drop them an email too. 1: Autofocus in Pro Mode seems unreliable, I had my phone on a stand then stepping in front of it and the AF...
