Info
e.
Hi everybody
I need one info because I am having s22 ultra already 3 months and before 20 days when I wanted to unlock phone shortly I saw like some screen issue. It was green screen with pixels and lines showen but very shoetly like one second like some kind of deffect a hole screen and than it was gone and today again but two times cery shortly when I am unlocking the phone.Can somebody say me maybe what is it and if happened to somebody.Thanky you all *1f44b.png**1f44b.png*
    Sofern das Problem nicht durch einen Sturz entstanden ist, würde ich das Gerät einschicken. Wenn das Problem von Werk aus existierte, sollte die Garantie die Reparatur abdecken.
    Wenn du das Gerät bei Samsung im Onlineshop gekauft haben, würde ich zuerst den Support kontaktieren. Wenn du es bei einem anderen Händler gekauft hast, würde ich den Händler kontaktieren.
    Danke Nein, mein Handy ist in diesen 3 Monaten noch nie runtergefallen, es wurde in Frankfurt im 02 Laden gekauft
    My Google wallet stopped working when I got in the beta tester, but now it seems like I have the final version from the one ui 5 and the wallet still doesn't work. Anyone with the same problem? Any solution? 6289296
    Hi all, so i just got my hand on my S22 Ultra two days ago, and i cant say im satisfy with it. Bought it new form Samsung direct, but since i received it, it has frozen twice and had to be forced to reset, i also cant get a few gesture features to work, like the screenschot one. Is there anyone...
    Hi, I have a samsung s22, I sent it under warranty 2 times, the first time it didn't turn on, it went into download mode by itself and I sent it to a Samsung service in Poland, they fixed it but they didn't glue the back cover well and scratched the frame several places, I reported the problem...
    Q
    I have dead spots in my note 10 plus screen , the s pen seems to work totally fine but the touch screen have dead spots and sometimes it works and sometimes it doesnt , when i lock and unlock screen it gets fixed for some milliseconds, i tried safe boot , restarting , removed the case , turned...
    L: Galaxy S22 Ultra hello everyone, i have just switched from apple a couple of weeks ago. I bought this phone since it was the flagship of samsung, however ever since i switched i was never satisfied with anything from this device. I am an esports player and some of these issues are really...
