Unreliable Samsung Repairs & Poor Support
  • Samsung TV: So beheben Sie den Fehlercode 107
    Samsung TV: So beheben Sie den Fehlercode 107Wenn Ihr Samsung-Fernseher den Fehlercode 107 anzeigt, kann das entweder an einer fehlerhaften Firmware oder an falschen TV-Einstellungen liegen. Zum Glück können Sie beide Probleme selbst beheben. In diesem Artikel wird erklärt, wie.
  • Samsung TV Modell herausfinden: So geht´s
    Samsung TV Modell herausfinden: So geht´sUm das Modell Ihres Samsung-Fernsehers herauszufinden, gibt es mehrere Möglichkeiten. Am einfachsten ist es, wenn Sie die Einstellungen im Menü des Fernsehers aufrufen.
If you want to play something like a game (Genshin impact) is playable up to a point where the game is start to freeze and if i want to see my fps with the app from the developer options,all is ok i can see the fps but after the gallery,Instagram,Snapchat it will start to crash.This problem you...
Hi all, so i just got my hand on my S22 Ultra two days ago, and i cant say im satisfy with it. Bought it new form Samsung direct, but since i received it, it has frozen twice and had to be forced to reset, i also cant get a few gesture features to work, like the screenschot one. Is there anyone...
X
My S22 Ultra is rejecting calls from one contact only although I don't have them on blocked list. The contact has 2 phone numbers and when they call me from either of them the call will get rejected after one ring only!! I deleted the content and resaved it again, it didn't help! I checked...
X
X
This option is very useful. I use it while playing music on Bluetooth speaker while keeping the output of other apps on phone speaker, but it's not working properly in my s22ultra one ui5.1 Every time I need to turn it on and off in settings to make it work. Who experienced the same? 8167578
Hello, I bought S22 ultra few days back. It is brand new. After setting up the device it got many updates and the latest update is One UI 6 based on android 14. I have seen significanr battery draining. For example if I charge it full then unplug it, in the morning I see 19% charge is already...
