Unreliable Samsung Repairs & Poor Support
r.
Hi, I have a samsung s22, I sent it under warranty 2 times, the first time it didn't turn on, it went into download mode by itself and I sent it to a Samsung service in Poland, they fixed it but they didn't glue the back cover well and scratched the frame several places, I reported the problem, they sent me a second time to glue the back cover well and change the scratched frame, but the surprise is the crisis or the workers are not paid because they painted the scratches and the cover was not glued, the phone is resistant to water, now I don't think there is any more.
How is it possible for a company as big as Samsung, the second in the world to build ships, military equipment and many others, to paint the phone frame, I can't believe it.
I really like Samsung products, all the ones I have from them is the first time I send something for service, but I think I will give up this brand and buy products from another brand that provides good service.
The online support isn't prompt either, it doesn't really respond, and when it does, it responds vaguely without too many details.
A good day.
  • Samsung TV: So beheben Sie den Fehlercode 107
    Samsung TV: So beheben Sie den Fehlercode 107Wenn Ihr Samsung-Fernseher den Fehlercode 107 anzeigt, kann das entweder an einer fehlerhaften Firmware oder an falschen TV-Einstellungen liegen. Zum Glück können Sie beide Probleme selbst beheben. In diesem Artikel wird erklärt, wie.
  • Samsung TV Modell herausfinden: So geht´s
    Samsung TV Modell herausfinden: So geht´sUm das Modell Ihres Samsung-Fernsehers herauszufinden, gibt es mehrere Möglichkeiten. Am einfachsten ist es, wenn Sie die Einstellungen im Menü des Fernsehers aufrufen.
Dann wende Dich an den Händler und gebe es komplett zurück.
So macht es ja absolut kein Sinn.
Okay,thats a pitty !
But ,how can we help you with this problem?
This is a user forum!
Samsung is not here and dont read your post !Maybe you can call again the Support ,because normally you have a better support as you told us !
I cant belive that the support broke your phone and destroied it a bit !
This is very strange !
I hope for you the next support can help you and fix the problem!
"normally you have a better support"....du bist ja auch schon länger im Forum und solltest anhand der vielen Beiträge wissen, wie der Support wirklich ist!
Aus eigener Erfahrung kann ich dir sagen ,dass der Support wesentlich besser als beschrieben ist !
Mir wurde immer geholfen und ich wurde meistens sehr nett behandelt nur einmal nicht.
Hallo, das Telefon wurde im Samsung Online Shop gekauft.
Ich habe sie kontaktiert und sie sagten mir, ich solle es im Rahmen der Garantie an einen Samsung-Service in Polen senden.
Hast du denn (des öfteren) Smartphones zur Reparatur nach Polen geschickt ?
Richtig !
Dass Geräte beschädigt aus Polen zurückkehren, liest man hier leider immer wieder.
Dann ruft man beim Support an und telefoniert solange bis sie dein Gerät wieder einschicken und es reparieren und zwar kostenfrei!
Den der Schaden haben die ja verursacht!
Warum hast du den Beitrag in Englisch abgefasst ?
Anscheinend sprichst du perfekt Deutsch.
Ganz einfach.
Weil der Samsung Reparatur Service in Polen ist.
Das könnte man mitbekommen haben.
Viel Glück dabei !
Genau das hat der Verfasser dieses Beitrags ja gemacht.
Nur leider hat der Samsung Reparatur Service in Polen den Schaden (Kratzer) nicht repariert sondern nur notdürftig überpinselt.
Wie oft würdest du in so einem Fall immer wieder anrufen und das Gerät immer wieder einsvhiicken ?
Doch ,es macht insofern Sinn, als dass andere Members aufmerksam gemacht werden.
Das kann doch nicht sein !
Dann rufst du beim Samsung Support an und sagst den das Problem.
Hi all, so i just got my hand on my S22 Ultra two days ago, and i cant say im satisfy with it. Bought it new form Samsung direct, but since i received it, it has frozen twice and had to be forced to reset, i also cant get a few gesture features to work, like the screenschot one. Is there anyone...
If you want to play something like a game (Genshin impact) is playable up to a point where the game is start to freeze and if i want to see my fps with the app from the developer options,all is ok i can see the fps but after the gallery,Instagram,Snapchat it will start to crash.This problem you...
X
My S22 Ultra is rejecting calls from one contact only although I don't have them on blocked list. The contact has 2 phone numbers and when they call me from either of them the call will get rejected after one ring only!! I deleted the content and resaved it again, it didn't help! I checked...
X
I got my long waited S22 Ultra yesterday after more that 5 weeks of waiting. Unfortunately I don't have yet the USB C dock charger so I used the old one to charge it. Today I connect it to my laptop with the USB C cable provided in the box, surprise!!! the cable works only on the "charging port"...
X
This option is very useful. I use it while playing music on Bluetooth speaker while keeping the output of other apps on phone speaker, but it's not working properly in my s22ultra one ui5.1 Every time I need to turn it on and off in settings to make it work. Who experienced the same? 8167578
